Geoprocessing - How to import layer symbology with value field?
4196
10-28-2014 12:25 PM
ShaningYu
Honored Contributor
I created a ModelBuilder.  In the last step, a feature class is generated.  I applied the Apply Symbology from Layer tool to this layer by importing a symbology layer file.  In manually setting up the layer's symbology, there are 2 steps: 1) Import the lyr file, and 2) Set the Value field.  However, when I used the Apply Symbology from Layer tool, there is NO 2nd step for setting the Value field.  As the result, the feature layer's sybmolgy still picks up teh default, rather than the lyr file defined.  Is it possible to add a parameter/variable to solve this problem?  If yes, could you help me How-To-Do?  Thanks.
ShaningYu
Honored Contributor
This problem got solved somehow.  Please ignore the Q of the thread.  Thanks.
