Error When Running Calculate Value
7436
27
08-31-2016 03:21 PM
ChrisHolmes
Hello Everyone,
I have a model which runs the calculate value tool:
The code in the tool is:
When the model runs the following errors are displayed:
I'm not sure what the errors are related to. What's strange is that the code does seem to execute: it displays the extent of the site_polygon layer, sets the scale to 1:4000, then creates the JPG file.
Any insights appreciated. Thanks!
ChrisHolmes
Thanks Xander. So with those changes it does seem to change the extent of the dataframe:
Executing: ExportMXD2JPG32 LOC2016-003
Start Time: Thu Sep 01 15:53:39 2016
Running script ExportMXD2JPG32...
Using MXD H:\chris\LOC2016-003\LOC2016-003 - actual_use.mxd
DF extent on startup is: -9047.84819850156 5650698.4605047 -8349.34680149874 5651193.7614953 NaN NaN NaN NaN
DF scale on startup is: 4000.0
extent of lyr: -10106.7650000002 5656720.382 -10069.7270000003 5656763.791 NaN NaN NaN NaN
extent of new_extent: -10106.7650000002 5656720.382 -10069.7270000003 5656763.791 NaN NaN NaN NaN
DF extent after assignment is: -10437.4966985017 5656494.4360047 -9738.99530149886 5656989.7369953 NaN NaN NaN NaN
DF scale after assignment is: 4000.0
Exporting to JPEG: H:\chris\LOC2016-003\LOC2016-003 - actual_use.jpg
Error: PageLayoutObject: Error in executing ExportToJPEG
Completed script ExportMXD2JPG32...
Failed to execute (ExportMXD2JPG32).
Failed at Thu Sep 01 15:54:14 2016 (Elapsed Time: 35.46 seconds)
But this now seems to bring around a new error. Thanks again
DanPatterson_Retired
Chris...
maybe try locations without '-' and spaces just for a check
might be a good suggestion
XanderBakker
Esri Esteemed Contributor
Another thing you might want to try is to export to another format (like PDF or PNG) to see if this yields the same error.
ChrisHolmes
That's a good idea. Thanks Xander.
ChrisHolmes
Thanks Dan, I'll give that a try.
ChrisHolmes
Well, that worked! Nice clean results and the expected result on the map:
Start Time: Fri Sep 02 08:42:29 2016
Exporting to JPEG: H:\chris\test.jpg
Succeeded at Fri Sep 02 08:43:07 2016 (Elapsed Time: 38.43 seconds)
I always have to remember the whole Modelbuilder doesn’t like spaces! It just needs to become a practice.
A big thanks to both Xander and Dan for all the help.
ChrisHolmes
Thanks Dan. Funny how it's easy to miss the tiny things. It didn't fix the errors though. I did find though that by commenting out mxd.save() it executes correctly. Not sure why it doesn't want to save to that location.
ChrisHolmes
I thought I would post the final script that created the expected results in the jpg file:
def main():
    import arcpy
    # will overwrite existing jpg
    arcpy.env.overwriteOutput = True
    # read the parameter from the tool
    loc_no = arcpy.GetParameterAsText(0)
    # define the path of the mxd
    mxd_file = r'H:\chris\{0}\{0} - actual_use.mxd'.format(loc_no)
    jpg_file = r'H:\chris\{0}\{0}-actual_use.jpg'.format(loc_no)
    if arcpy.Exists(mxd_file):
        arcpy.AddMessage("Using MXD {0}".format(mxd_file))
        try:
            mxd = arcpy.mapping.MapDocument(mxd_file)
            df = arcpy.mapping.ListDataFrames(mxd)[0]
            arcpy.AddMessage("DF extent on startup is: {0}".format(df.extent))
            arcpy.AddMessage("DF scale on startup is: {0}".format(df.scale))
            lyr = arcpy.mapping.ListLayers(mxd, 'site_polygon', df)[0]
            ext = lyr.getExtent()
            arcpy.AddMessage("extent of lyr: {0}".format(ext))
            new_extent = df.extent
            new_extent.XMin, new_extent.YMin = ext.XMin, ext.YMin
            new_extent.XMax, new_extent.YMax = ext.XMax, ext.YMax
            arcpy.AddMessage("extent of new_extent: {0}".format(new_extent))
            df.extent = new_extent
            df.scale = 4000
            arcpy.AddMessage("DF extent after assignment is: {0}".format(df.extent))
            arcpy.AddMessage("DF scale after assignment is: {0}".format(df.scale))
            arcpy.AddMessage("Exporting to JPEG: {0}".format(jpg_file))
            arcpy.mapping.ExportToJPEG(mxd, jpg_file)
            del mxd
        except Exception as e:
            arcpy.AddError("Error: {0}".format(e))
    else:
        arcpy.AddWarning("MXD {0} not found!".format(mxd_file))
if __name__ == '__main__':
    main()
Something interesting is that while the image exported is what I'm expecting:
Nothing ever changed in the map window from when the mxd opened. I always expected that the extent would change in the map window and then the image would be created based on that:
