Error When Running Calculate Value
7455
27
08-31-2016 03:21 PM
ChrisHolmes
Hello Everyone,
I have a model which runs the calculate value tool:
The code in the tool is:
When the model runs the following errors are displayed:
I'm not sure what the errors are related to. What's strange is that the code does seem to execute: it displays the extent of the site_polygon layer, sets the scale to 1:4000, then creates the JPG file.
Any insights appreciated. Thanks!
ChrisHolmes
Hi Xander,
I'm going to attach a file with a table showing on the left the code in the Calculate Value tool and on the right the code in the python script you sent me (thanks again!). The row below the row with the code shows the jpg file created using both methods. The one for the Calculate Value tool shows the correct image, the one for the python script shows the mxd as it appears when it's opened up (so it doesn't seem to do what's in the code). To me the code in both methods looks the same so I don't know why the code in the python script doesn't seem to run?
XanderBakker
Esri Esteemed Contributor
Strange, supposedly arcpy will refresh the active view when something is changed. I would have to set up a similar situation te be able to track the issue, but I don't have time for that. Could you change the code to this (some additional messages):
def main():
    import arcpy
    # will overwrite existing jpg
    # read the parameter from the tool
    loc_no = arcpy.GetParameterAsText(0)
    # define the path of the mxd
    mxd_file = r'H:\chris\{0}\{0} - actual_use.mxd'.format(loc_no)
    jpg_file = r'H:\chris\{0}\{0} - actual_use.jpg'.format(loc_no)
    if arcpy.Exists(mxd_file):
        arcpy.AddMessage("Using MXD {0}".format(mxd_file))
        try:
            mxd = arcpy.mapping.MapDocument(mxd_file)
            df = arcpy.mapping.ListDataFrames(mxd)[0]
            arcpy.AddMessage("DF extent on startup is: {0}".format(df.extent))
            arcpy.AddMessage("DF scale on startup is: {0}".format(df.scale))
            lyr = arcpy.mapping.ListLayers(mxd, 'site_polygon', df)[0]
            ext = lyr.getExtent()
            arcpy.AddMessage("extent of lyr: {0}".format(ext))
            df.ext = ext
            df.scale = 4000
            arcpy.AddMessage("DF extent after assignment is: {0}".format(df.extent))
            arcpy.AddMessage("DF scale after assignment is: {0}".format(df.scale))
            arcpy.AddMessage("Exporting to JPEG: {0}".format(jpg_file))
            arcpy.mapping.ExportToJPEG(mxd, jpg_file)
            mxd.save()
            del mxd
        except Exception as e:
            arcpy.AddError("Error: {0}".format(e))
    else:
        arcpy.AddWarning("MXD {0} not found!".format(mxd_file))
if __name__ == '__main__':
    main()
... just to see what is going on?
ChrisHolmes
Thanks Xander. Here are the results:
Executing: ExportMXD2JPG2 LOC2016-003
Start Time: Thu Sep 01 13:22:29 2016
Running script ExportMXD2JPG2...
Using MXD H:\chris\LOC2016-003\LOC2016-003 - actual_use.mxd
DF extent on startup is: -9047.84819850156 5650698.4605047 -8349.34680149874 5651193.7614953 NaN NaN NaN NaN
DF scale on startup is: 4000.0
extent of lyr: -10106.7650000002 5656720.382 -10069.7270000003 5656763.791 NaN NaN NaN NaN
DF extent after assignment is: -9047.84819850156 5650698.4605047 -8349.34680149874 5651193.7614953 NaN NaN NaN NaN
DF scale after assignment is: 4000.0
Exporting to JPEG: H:\chris\LOC2016-003\LOC2016-003 - actual_use.jpg
Completed script ExportMXD2JPG2...
Succeeded at Thu Sep 01 13:22:59 2016 (Elapsed Time: 29.68 seconds)
XanderBakker
OK, so the dataframe extent is not being changed when the layer extent is assigned. Could you try this code?
def main():
    import arcpy
        try:
            new_extent = df.ext
            new_extent.XMin, new_extent.YMin = ext.XMin, ext.YMin
            new_extent.XMax, new_extent.YMax = ext.XMax, ext.YMax
            arcpy.AddMessage("extent of new_extent: {0}".format(new_extent))
            df.ext = new_extent
            df.scale = 4000
            mxd.save()
            del mxd
    else:
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ChrisHolmes
Thanks Xander. When I run that code, I get the following error message:
Executing: ExportMXD2JPG3 LOC2016-003
Start Time: Thu Sep 01 14:21:14 2016
Running script ExportMXD2JPG3...
Error: 'DataFrame' object has no attribute 'ext'
Completed script ExportMXD2JPG3...
Failed to execute (ExportMXD2JPG3).
Failed at Thu Sep 01 14:21:32 2016 (Elapsed Time: 17.89 seconds)
Thanks for your help, very much appreciated!
DanPatterson_Retired
the df extent has to be set to the extent right now it isn't being assigned properly as it is further on... (I think... Xander you will have to check
ChrisHolmes
Thanks Dan. That seems to have fixed the error. The results now display as:
Start Time: Thu Sep 01 14:35:03 2016
extent of new_extent: -10106.7650000002 5656720.382 -10069.7270000003 5656763.791 NaN NaN NaN NaN
Succeeded at Thu Sep 01 14:35:40 2016 (Elapsed Time: 36.85 seconds)
Still seems though that the extents are not changing.
ahhhh/!  new_extent = df.extent   or you will have to wait for Xander
ChrisHolmes
It seems to have dealt with the error. But the data frame extents still do not seem to take the value of new_extent.
Thank you Dan
XanderBakker
double oops, line 22 as Dan mentions should be
and line 26 should be :
df.extent = new_extent
