Cannot access sorted files from ModelBuilder
1689
03-28-2016 07:32 AM
SofieWikberg1
Hi!
When I use the tool "Sort" within modelbuilder I  can not access the resulting file from other tools within modelbuilder in order to continue with the model. If I, for example, sort the file PR into PR_sort and then try to add a field I get this message:
"ERROR 000229: Cannot open C:\LN_Slump\PR_sort. Failed to execute (Add Field)." Or if I try to rerun the sorting I get "
ERROR 000210: Cannot create output C:\LN_Slump\P_sort. Failed to execute (Sort)."
Doing the same things outside modelbuilder by using one tool at time is absolutely no problem (but very unpractical).
Does anyone have a suggestion to what might be wrong and how to solve the problem?
I am using ArcGIS 10.2.2 3552
Sofie
SofieWikberg1
Problem solved! I got help and I had to add .shp to the end of the Sort function Output Dataset. /Sofie
