Can I use modelbuilder to locate shapefiles in a folder?
1904
04-01-2020 09:22 PM
JustinOdell
Is it possible to create a model that searches through an input folder to locate shapefiles meeting a specific criteria, then output the result? How might this be best achieved?
DanPatterson_Retired
If you can find a tool in the Toolboxes, it can be used in a model, otherwise, python scripting.
Walk—Data Access module | Documentation for traversing folders and locating featureclasses would be a start
curtvprice
It would be helpful to know what criteria and why.
If the shapefiles are all in one folder, the Calculate Value tool with a python function that uses arcpy.ListFeatureClasses() would do it. Less complicated than arcpy.da.Walk.
In pure ModelBuilder, you could use Iterate Feature Classes in a submodel that returns a multivalue with the list.
JonathanCarruthers-Jones
I have tried this  solution (see my post of 29/4/20) but cannot get it to work either as it outputs only a single file.
Can you give us a bit more detail on how this proposed solution would work in model builder ?
Thanks !
curtvprice
I think you are doing it right, I found your post and added a test model to this thread:
Sub-model cannot iterate features with same name ?
