ArcPro model fails due to empty out
1140
09-25-2018 09:36 AM
Lebowski
I am in the process of building several models for a project.  I am trying to build a version that preforms in ArcMap and duplicating that model in ArcPro or vice versa.
One particular model I have built iterates a clip function across a GDB. I knew prior to building the models that there would be empty outputs depending on the clip extent. ArcMap is fine with the empty outputs but ArcPro is not. It is that same exact model except for I built one in ArcMap 10.6.1 and the other in ArcPro, I did NOT run model built in ArcMap in ArcPro or vice versa. Same parameters, same output, etc.
Has anyone else experienced this issue?
JakeSimms1
Chad,
Good question. Whats the error you are receiving when running your model in Pro?
