Adding Input Field to Field Map issue
1644
09-23-2019 07:27 AM
SMauri
Something wrong when I select manually match field for an output field.
I select a source for a field, e.g. DIA. Then I click OK to save as usual...nothing special.
Then I open Append block again to add another field, but previous insert was gone...
I made also a video to prove it: ArcGIS Pro Append bug - YouTube
ArcGIS Pro 2.4.1
Anyone has this issue?
Cheers
Stefano
SMauri
It's a known bug.
This is what Esri Support tell me about this problem:
#BUG-000111603 In ModelBuilder, the Append tool setting for the 'Use the Field Map to reconcile schema differences' option does not preserve the field mapping selected
Cheers
Stefano
Sveinung_Bertnes_Råheim
THis happens all the time. Seems like it works better if field names are the same. The even more frustrating situation is that sometimes it works. THen, next time I run the model, it does not work.
This has costed me hours of work.
SMauri
It's a known bug.
Cheers
Stefano
