1:M Join In Model Builder
2628
07-09-2020 09:33 AM
gishelpdesk1
Hi all,
I am using model builder and joining a (non spatial) table to a feature class based on matched addresses.
This works OK but if there is more than one of the same address (which there can be) it's only joining the first address and not the others. I know I need to do a 1:Many join but can't see an option to add this tool in model builder. I know you can specify a 1:M in spatial join but one of my tables is not spatial.
Any help would be most appreciated
LukasFalk
Hello there!
Unfortunately in all cases of 1:M joins, only the first matching record is joined and displayed in the attribute table.  You can confirm this with the screen shot below.   This screen shot was pulled from the following URL.
About joining and relating tables—Help | Documentation
There is another workflow you can try to achieve the same result though.  The URL below contains a workflow that utilizes the Make Query Table geoprocessing tool to achieve a one-to-many join.  The workflow is outlined for ArcMap but the same tool exists in Pro if that's what you're using.  The second URL below is for a geonet thread in which someone asked the same question as you.  If you look down this thread you will find that someone outlines how they utilized the Make Query Table workaround in ArcGIS Pro to achieve a 1:M join.  You can use this information for additional guidance on how to complete the workflow.
How To: Create a one-to-many join in ArcMap
ArcGIS Pro Join One to Many Join by Attribute
I hope this helps!
Lukas
MarkYoung3
Hi Lukas - thank you for your reply.
I am trying to address match a non spatial table of addresses (and there can be more than one instance of the same address in this table)  to a point feature class. The make table query accepts the point feature class as an input table but won't accept the non spatial table as an input table.
Mark
MarkYoung3
Eventually got this to work. Both my tables needed to be in an enterprise gdb rather than an file gdb
Thanks again for your help
Mark
