Don't rerun entire model in ModelBuilder if previous steps already finished
1817
10-10-2022 08:56 AM
Status: Open
LoriMcCormack1
ModelBuilder reruns the entire model if I
1. Open a model and try to run a step, even if the previous steps show they have been run
a. Example: The previous step reprojected dispersed points layer into a feature class and I tried to run the append into an empty feature class step.  I don't want to rerun the entire model because dispersing symbols takes 35-45 minutes.  Plus the dispersed symbols are already saved in the reprojected feature class.
2. When I make a minor change to a step (changing a geoprocessing tool parameters), it reruns the whole model even though the model has already run up to that point.
2 Comments
rsun_TQB
Learn from FME Workbench cached mode will be the way to go 🙂
DrewFlater
This bug can be tracked with this Esri Support number: BUG-000150197
https://support.esri.com/en-us/bug/model-elements-rerun-when-the-tool-properties-are-opene-bug-00015...
