Connect Garmin GPS to ArcMap
4198
09-11-2014 02:49 AM
MonyrothLy
Dear everyone
     i always use DNRGarmin to transfer my coordinate to GPS. In my country, we use Datum: Indian 1960 UTM Zone 48N however it do not have this datum in the Garmin GPS. i need to convert from Indian 1960 to WGS 1984 then transfer using DNRGarmin. do you have another solution.
     how to connect Garmin GPS direct to ArcMap?
Please Help
Best Regard
OwenEarley
The MxGPS‌ Add-In can connect to a Garmin GPS directly from within ArcMap and it can also apply a datum transformation for any of the supported coordinate systems in ArcGIS, for example:
Otherwise, you could project your data to WGS84 before transferring it using DNRGarmin.
