Filter Survey123 Survey Forms based on Portal
1243
07-05-2018 06:20 AM
FinnianO_Connor
If you are a member of multiple portals e.g. ArcGIS Online, ArcGIS Enterprise etc you can have survey forms from different sources within the application. To submit data you need to be singed in to the correct portal. It would be helpful to only show survey forms based on the signed in active portal. Is this possible?
Finnian
JeffShaner
Finnian,
Thank you for your feedback. I have passed this information on to the Survey123 team for consideration. I encourage you to submit a support ticket for this as well so that you can track its progress.
Thanks
Jeff
