Fetching data - inside which borders are coordinates?
1084
10-23-2022 05:12 PM
AngeloWillems
Hi everyone, I'm Angelo from Aruba. And I am looking for a way to extract/fetch metadata from another user's layer over the map of Aruba. Specifically the Central Bureau of Statistics has created a layer with Economic Zoning, each zone has a different policy and regulation for construction etc.
You can see the map with the layer at the following link:
https://www.arcgis.com/apps/webappviewer/index.html?id=38891684b5404974a15860c00a0defd6
In the upper left corner there is a search box, where you can input the coordinates e.g. 12.59937465, -70.04223917 and it will pinpoint the location on the map.
You can then click on the map / layer and a window pops up with the data about the specific zone that location is in.
I have a database with thousands of local listings that is updated every day and I would like to include zoning information as a feature to each listing to enrich the dataset.
Ideally I would like to use Python to make an API call using the coordinates as input and receiving the zoning info in return.
There is probably a straight forward way to do so, but I am struggling to get the answer on the site.
So far I pip installed arcgis and am able to initialise GIS() and view maps with IPyhton.display like described in the tutorial.
I guess my question is how can I see another user's layer and get data from that layer based on coordinates as input?
Really appreciate any help.
Thank you
DaraBurlo
Esri Alum
Thanks for bringing your question to Esri Community, @AngeloWillems .
Because this area is used for members to provide our team with feedback about our online community, I'd like to help get your post moved over to one of our conversation boards where it's more likely to be seen and responded to by members who can help. Try the ArcGIS Web AppBuilder Questions Board to see if community members can help point you in the right direction.
Please do also feel encouraged to share a new post in our Member Introductions board to tell us a bit about yourself. Our team and your GIS peers around the globe would love to learn more about you!
