why can't I create valid polygons
6983
10
04-30-2015 01:31 PM
JamesHarrington
I have a personal geodatabase polygon feature class. I started and edit session, created several features. I tried to create another feature and no matter what I do it doesn't work. Only creates empty geometry, i.e. shape_length and shape_area fields are zero. Did not change coordinate system, not going out of bounds, why is this happening???? SO SICK OF ESRI GARBAGE!!!!!!!
JoeBorgione
I've been using 'ESRI garbage' for over 25 years; never had a problem creating a polygon.  I make a darn good living with ESRI products as well.  Perhaps you can cool your jets long enough to provide some additional information and we may be able to better assist you.
That should just about do it....
DarrenWiens2
In ArcCatalog, go into the feature class properties. Delete and recreate the spatial index. Fixes some random geometry problems.
JamesHarrington
HI
Thanks, I tried this, I think It made it worse? But looking at it the porblem may be that I'm in a data frame and most other feature classes are NAD27, my class is NAD83, so may be a problem with transformation. But I don't undetstand why I created 3 features no problem, and is suddenly stopped working. I'll try reproduceing the class in NAD237 and see how that works. thanks!
To: James Harrington <[email protected]>
Sent: Thursday, April 30, 2015 4:45 PM
Subject: Re: - why can't I create valid polygons
#yiv9409821848 * #yiv9409821848 a #yiv9409821848 body {font-family:Helvetica, Arial, sans-serif;}#yiv9409821848 #yiv9409821848 h1, #yiv9409821848 h2, #yiv9409821848 h3, #yiv9409821848 h4, #yiv9409821848 h5, #yiv9409821848 h6, #yiv9409821848 p, #yiv9409821848 hr {}#yiv9409821848 .yiv9409821848button td {}
GeoNet
reply from Darren Wiens in Mapping - View the full discussionIn ArcCatalog, go into the feature class properties. Delete and recreate the spatial index. Fixes some random geometry problems.
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Mapping by email or at GeoNet
Following why can't I create valid polygons in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
JayantaPoddar
Hi James,
What is the coordinate system you are using?
You could try Repair Geometry.
Think Location
JamesHarrington
State plane NAD83, though my frame and most other layers in the map are NAD27 so that might be the problem, I'm going to try recreating the class in NAD27? thansk for your help
Sent: Friday, May 1, 2015 5:41 AM
#yiv7046637269 * #yiv7046637269 a #yiv7046637269 body {font-family:Helvetica, Arial, sans-serif;}#yiv7046637269 #yiv7046637269 h1, #yiv7046637269 h2, #yiv7046637269 h3, #yiv7046637269 h4, #yiv7046637269 h5, #yiv7046637269 h6, #yiv7046637269 p, #yiv7046637269 hr {}#yiv7046637269 .yiv7046637269button td {}
GeoNet
reply from Jayanta Poddar in Mapping - View the full discussionHi James,What is the coordinate system you are using?You could try Repair Geometry.
RebeccaStrauch__GISP
James, I didn't see what version you are running, but I wonder if you are hitting the limitation of the personal geodatabase (which is based on Access and does have limitations)?  That might be why after three successful adds it has problems.
I would recommend using a File geodatabase which is a much more robust format, and is supported moving forward.
Five reasons why you should be using the File Geodatabase | ArcGIS Blog
If you need help setting a file GDB up, this is the help from 10.2 ArcGIS Help (10.2, 10.2.1, and 10.2.2)   it is similar in previous versions, but you can search in the help if this version doesn't work for you.
I hope that helps.
JamesHarrington
I have had problems with file geodatabases. Data will not display at certain scales, and I have layers set to be shown at all scales. This has been a problem with multiple file geodatbases, which does not happen in personal geodatbases. I also find it useful to work with data tables in Access, since Arcview/ArcCatalog are very restrictive in editing tables.
Sent: Saturday, May 2, 2015 12:53 AM
#yiv4778050979 * #yiv4778050979 a #yiv4778050979 body {font-family:Helvetica, Arial, sans-serif;}#yiv4778050979 #yiv4778050979 h1, #yiv4778050979 h2, #yiv4778050979 h3, #yiv4778050979 h4, #yiv4778050979 h5, #yiv4778050979 h6, #yiv4778050979 p, #yiv4778050979 hr {}#yiv4778050979 .yiv4778050979button td {}
GeoNet
reply from Rebecca Strauch in Mapping - View the full discussionJames, I didn't see what version you are running, but I wonder if you are hitting the limitation of the personal geodatabase (which is based on Access and does have limitations)?  That might be why after three successful adds it has problems. I would recommend using a File geodatabase which is a much more robust format, and is supported moving forward. Five reasons why you should be using the File Geodatabase | ArcGIS Blog  If you need help setting a file GDB up, this is the help from 10.2 ArcGIS Help (10.2, 10.2.1, and 10.2.2)   it is similar in previous versions, but you can search in the help if this version doesn't work for you. I hope that helps.
DarrenWiens2
Unfortunately, there are several warnings indicating that editing feature classes in Access is risky and may corrupt the geodatabase, such as: http://support.esri.com/cn/knowledgebase/techarticles/detail/31599
RakeshSinha
James,
Just for testing purpose would you mind exporting out your feature class from the existing personal geodatabase to a new personal geodatabase  and then perform some edits. I would like to see if it retains your edits with proper shape area and without 'null' geometry. However, as Rebecca suggested File geodatabase is a native file format of Esri with a lot of capabilities. I would work with a file geodatabase instead of a personal geodatabase. Thanks!
