What to do about ArcMap crashing when zooming in Layout view
4990
02-28-2017 10:24 AM
RyanStephenson
When I swap to layout view and attempt to zoom to an extent in my data frame it immediately crashes. This happens when I use the data zoom tool, or when I try to zoom to a layer. What is going on? How can I fix this? I am using ArcGIS Desktop 10.4.1, and I don't get technical support?!?!
AbdullahAnter
Honored Contributor
DanPatterson_Retired
The first thing is to confirm that this only occurs in one project or all projects.  If it is the former, then it could be a data issue making it easier to track down simply by removing data layers and retesting.  If it is in all cases, then you do have an installation issue.
