Trouble creating report in Model Builder
2688
08-12-2013 04:24 PM
LouisWasson
Hello
I've created a Model Builder application that creates a query table of attribute data on damaged buildings and all inventoried items in each building. Example, a tornado path has destroyed or damaged buildings. The query table contains information on each building plus inventoried items inside each building. The generated query table is a nice dataset but I'm struggling in how to generate a report along with the map. I've tried creating a .rlf file but can't get it right as the attribute table has many fields. I've read where Python can generate reports with reportexport but haven't tried that yet. Not sure where to start honestly.
My ultimate goal is to create a Map Book with each page being a building polygon and all its associated info.
Many thanks for your help!
lwasson
LouisWasson
Maybe a better way to illustrate the question is if you have an attribute table with 30+ fields how do you create a report with 8 or so fields per page for example?  When I try to work in the Create Report Wizard it puts all the fields on one page.
Hope this helps clarify my question.
Thank you!
Louis
