Suddenly none of the object on arcmap document select-able
6660
10
04-09-2015 11:38 PM
NaimeCelik
In arcgis 10.3 , after opening a arcmap document it was saved a day ago, it appeared none of the object is selectable. I can only select object when I go attribute table and select one line, then object appears as selected. I have no idea why this is happening. İf  I move any layer to a new arcmap document, it is still not selectable. What could be the reason? Is there anyone who had similar problem?
NaimeCelik
No, they do not, how can I make then selectable?
