Select tool in schematic editor for ArcGIS 10
1644
08-09-2012 09:23 AM
AshleeBeard
I'm using ArcMap version 10 and I cannot find the select elements tool in the schematic editor toolbar.  Where can I locate this or is there an alternative?
RickAnderson
That is a standard tool on the toolbar, so if it is missing, I would question the installation or the map doc template that you are using.  You might want to delete the normal.mxt file your user settings so that it 'resets' to default.  Other than that, all of the tools on the toolbar are available in the customize dialog.  So you can Customize on the toolbar and then choose the Customize Mode.  Go to the Commands tab on the Customize dialog.  Scroll down and select schematics from the categories list and then find the Edit/Move Schematic Features tool in the commands list.  Now you can drag/drop that onto a toolbar.
RickAnderson
I guess I should note that if you are only 'selecting' elements, you can use the core Select Features tool from the main toolbar.  The schematic tool does do selection, but also allows for moving things.
