Searching for feature classes using Python script
1475
5
03-08-2011 08:13 AM
KevinHigh
Hi all,
I'm wondering if it's at all possible to create a python script that can search for a particular feature classe in all mxds within a folder and all its subfolders. I would also like it to create an output .txt report similar to what MultiMXDReport.py does, but it would create a list of mxds that contain just the specified feature class.
For example, if I specify "Transmission_Main" as the feature class and "T:\\Maps\" as the folder path, it would create a list of all mxds within "T:\\Maps\" that contain the "Transmission_Main" feature class.
I'm very new to Python, and any thoughts or clues to put me in the right direction would be greatly appreciated.
Kevin
JeffBarrette
Hello Kevin,
Have you tried the Find Data Source sample?  I think it does exactly what you want.  You mention the multi-mxd reporter tool so I assume you are familiar with the arcpy.mapping sample script tools on the resource center.
If not, try the following link:
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=A910AB18-1422-2418-3418-3885D...
Jeff
KevinHigh
Jeff,
Thanks for the response. That is the tool I was looking for.
My only problem now is that the feature classes I'm interested in are stored on a 9.3 version SDE. Is there any way to get around this? I'm thinking the answer is no, so I'll just have to wait until will upgrade it to 10.
Thanks again.
K
JeffBarrette
Kevin,
The script must run on a 10.0 machine because arcpy.mapping is new at 10 but it should not matter that the feature classes are coming from a 9.3 SDE source.
Please let us know if there is a problem,
Jeff
KevinHigh
The feature classes I'm interested in are stored on a 9.3 SDE source. When I run the tool to find feature classes stored on this SDE, the output text file shows that no sources were found - even though I am running it on maps that do contain the feature classes I am searching for.
However, the tool works perfectly when I run it on maps containing feature classes on our 10 SDE.
Is there any way to explain why this would be happening? Am I just missing something?
Thanks again,
Kevin
JeffBarrette
Are you running 10.0 SP1.  The was reported a long time ago but I believe it was not reproducible using SP1.
