Schematic - different RouteID when generate schematic POL diagram from Network Analysis
4655
02-10-2015 09:22 PM
ThaoTruong
Hi Rick Anderson,
I generated 31 bus route by Network Analysis. Then created POL diagram. However, routes on schematic layer have completely different ID compare to bus route name in Routes Network Analysis. Please see the attached file.
What I'd like to do is to import the symbol from bus route on Network Analysis into Schematic route. Is there another way?
Thanks.
Thao
RickAnderson
Not sure what version you are using, but there is a bug in the system dealing with this.  It looks like it will be resolved in the upcoming 10.2.1 general utility patch 2 and also in 10.3.1.
