putting default annotation into standard geodatabase annotation class
4150
06-17-2015 08:23 AM
CherylJohnson1
Several years ago I spent quite a bit of time manually creating (default) annotation for a map.  I did not use labels.   Much of it was for things such as mountain ranges.  I'd like to put this in a standard geodatabase annotation class so that I can use it in other maps.  How would I do this?
Tags (1)
JacobTodd1
When you say that you created annotation manually, what method did you use? Did you insert text at specific locations? If so, a possible way to convert this to an annotation feature class is to:
  1. Select the text/annotation that you wish to convert.
  2. Right-click on the data frame in which the text/annotation resides.
  3. Choose Convert Graphics to Features.
  4. When the dialogue opens, choose your coordinate reference system and your output geodatabase.
JacobTodd1
CherylJohnson1
This works great!  Thank you.
