Problems using ModelBuilder & ToRaster tools ('Feature to Raster','Polyline to Rast')
2397
03-07-2012 05:24 PM
ArielleSimmons
I am in a roadblock with ModelBuilder (using ArcView 10, SP2).
I have a rather simple bit of model where I am just adding a field to a road dataset, populating it, and then converting it (based on the populated field) to Raster.  Simple beans, right? I've gotten this process to work independently outside of ModelBuilder using the same tools I've put into the Model Builder GUI. However, it will NOT RUN in ModelBuilder  :/!!!
Enclosing the piece of the Model. Notably it keeps shutting down at "Polyline to Raster" (I have also tried w/ Feature to Raster, same results). As far as datasets go, this seems like a ridiculously small dataset (only 9881 records). The error at crash (yes, ArcMap fully crashes routinely right at 'Polyline To Raster') is either a '99999' error or just a regular 'ArcMap has committed a serious error'.
Any thoughts?
by Anonymous User
Not applicable
Original User: adaminglis
What is the projection of your Roads file?  I've had bad experiences trying to use non-UTM projection in model builder.
JeffBarrette
If you don't get an answer, I'd suggest you try this post on the geoprocessing forum.  You'll have a much better targeted audience.
Jeff
