Print Template Sample Javascript Code
2241
05-14-2013 05:39 PM
nanasyazana
Hi, Im new here in GIS field,
Currently im working on web map application using javascript..
the sample of print template that you given is not working..
the print_button not show up..please look at back your coding and make it accessible for ease me to customize the other template for print..
i need to code print template of A0, A1, A3, and A4.. this is the link of print template esri webtemplate..
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/widget_print_esri_request.html
copy the javascript code and run the code.. the button not appear..
please respond it a.s.a.p...thank you..
