Overpass underpass edit tool
1312
08-15-2011 09:16 AM
KristinaKlees
Does anyone know where this particular tool resides?  I am trying to clean-up the messy edges of our road network at the large scales on the map and it is not coming through with the Community Maps Tools downloads from the website.  The only tool that comes through in the folder is the roadnetwork assist tool.  Thank you kindly, in advance.
ESRI_DBServices
Hello Kristina,
As you discovered, the overpass/underpass tool was removed from the template. A few glitches were found with the tool and are described in this blog: http://blogs.esri.com/dev/blogs/communitybasemap/archive/2010/12/23/how-to-edit-overpass_2f00_underp...
Since then, based on user feedback and our own experience inhouse, we found that it really wasn't as useful as we had hoped and that it's just as easy to manually edit the over/underpasses. The road network assist tool will still be of use if your duel carriageways collapse to a point at intersections.
