OLE frame in my map export
5351
11-13-2011 08:50 PM
XingLee
I'm trying to export/print maps using Data Driven Pages, but everytime I do an "OLE frame" text box appears in all my pdfs. I am using a pre-defined layout but I haven't imbedded any images/spreadsheets, etc so I don't know what is causing the problem. this issue only occurs when I export maps using Data driven pages and does not happen at any other time.
I'm guessing that the problem lies deeper in how ArcGIS10.0 is reading my files, but I'm no whiz with that. Perhaps it's to do with my layout template...
Thanks!
ChrisFox3
Hi Xing,
Would you be able to upload a map package to reproduce the issue?
XingLee
Turns out I had a residual object frame hidden under my data frame...
RobMower
Sorry for the thread revival, but I didn't see much point in starting a new one.
I too have this problem. I have a simple arcpy script that outputs to a map book PDF, which works fine, except for one of the layout elements which happens to be an OLE object (Word doc). The element is missing in the PDF; it just shows a blank frame where it should be with "(OLE Frame)" written inside. I have tried a blank mxd with just the OLE element inside as well as linking to two separate documents, both with standard fonts (Arial), but without any success. Normal exports from within ArcMap are fine.
Is there perhaps a parameter that needs to be set for the exportToPDF method for it to handle these elements correctly? Currently I have .exportToPDF(pdfPath,"ALL","","PDF_SINGLE_FILE"). I've tried setting embed_fonts="True" without any success.
I'm currently using ArcGIS 10 SP2 with Python 2.6.5.
Any ideas?
Thanks
RobMower
This is likely to be related to the known issues described in the article below. The workaround of pasting the object into the mxd isn't really ideal for what I want to achieve.
http://support.esri.com/en/knowledgebase/techarticles/detail/29569
JeffBarrette
This is a known limitation with OLE Objects and PDFs.
Jeff
