Missing choice in sympology tab
2881
08-09-2016 10:48 AM
MotasemWadi
In arcmap 10.3.1 when i go to layer properties then sympology there is a missing choice  which is "chart" all choices are there but i cant find the chart choice which it has bar and pie charts , what is the problem here ? My license is standard .
MotasemWadi
Thx dan for the reply , i tried the three types of vector data , point , line and polygon . the chart tab is missing also
DanPatterson_Retired
yes... but what field did you choose? etc...have a look at the example image in the 2nd link.
MotasemWadi
There is no chart button nothing to press , i tried a lot of data nothing worked
JenniferMcCall4
Hi Motasem,
Have you tried closing all Esri appications, re-naming the ESRI folder, then re-starting ArcMap?  Sounds like something could just be buggy with the settings of the install.
C:\Users\<username>\AppData\Roaming\ESRI
