making maps on ArcMap with travel direction instead on North Up
2869
03-15-2016 12:02 AM
ElieRizk
hello,
i know that my question is a little bit strange, but i would like to have a clear answer if it is possible to make map layouts having the travel direction instead of the North up using ArcMap.
thank you,
Salmon_ArmBC
You can rotate each data frame to whichever direction you want. Right-Click on the data frame and select Properties...
Select the General Tab and type the rotation you want (I typed in 180 to turn it so South is at the top of the frame)
AdrianWelsh
MVP Honored Contributor
Hi Elie,
What Laura said works. Another way is to add the Data Frame Tools Toolbar
Go to Customize --> Toolbars --> Data Frame Tools
Here, you can type in the rotation, or you can use the tool to the left (the Rotate tool) and physically drag the map around to the rotation you like.
When you go to the layout view and add a North Arrow, the arrow will reflect where North is supposed to be.
Salmon_ArmBC
I've never used the Data Frames Toolbar. That's way faster than my method!
