Legend not updating between ExportToPDF() calls
1345
04-13-2010 11:26 AM
DerekSwingley
I'm exporting some maps and turning layers off and on between exports. I'm expecting the legend to update in my exported .pdfs but it's not. I've logged this with support but figured I'd start a thread here too. Here's a piece of my script:
for lyr in lyrs:
 if lyr.name in layer_list:
  print 'Exporting', lyr.name
  lyr.visible = True
  df.extent = lyr.getExtent()
  export_path = pdf_base + lyr.name + '.pdf'
  arc.ExportToPDF(mxd, export_path)
  lyr.visible = False
Is there some way to force the legend to update? I was thinking changing the layer's visibility should trigger a legend update. Anyone else seen this?
DerekSwingley
Not many people around here I guess...
Support logged this as a bug for me:  #NIM056303  Map legend does not update based on layer visibility when exporting maps using arcpy.mapping.ExportToPDF()
Hopefully it will be fixed for final.
JeffMoulds
Thanks for your input. The plan is to have NIM056303 fixed for final.
