Lable formatting Tags:  NewLine
3131
05-20-2013 09:18 AM
RobertBorchert
Honored Contributor
In a label field we can insert text formatting tags.
I am using Maplex
For example in my Substation Table I have a Label field.  I populate the field as such.
<ita> Substation #14 (GRE)</ita>
and the resulting label is.
Substation #14
What I would like is to have a label that will display as
Substation
#14
I found tags for color, font size etc.
Keep in mind this is different than the Text String Expression.  This is actually in the attribute I am wanting to build this in.
Stack Labels should be the attribute I check, however, it is not always stacking them and I would like to have them centered.
LauraCoppola
If you go to the Option box for stack label (label manager>placement properties>fitting strategy) you have the option to force a split at a space (or a comma, an astrix, etc.) and if you're in 10.1 there is an option to constrain to center.
I don't remember the constrain to center option in 10.0, but the force split is definitely an option there.
Another thing to check is the minimum number of characters on a line. It defaults to 3 so that could be an issue for say, Substation #9
LauraCoppola
RobertBorchert
Honored Contributor
Thanks,  <insert hitting heel of hand on forehead sound> I have no idea how many times I saw the option box but didn't click on it.
