Key numbering duplicates
2315
12-30-2012 12:21 PM
by Anonymous User
Not applicable
Original User: [email protected]
I'm attempting to use Maplex key numbering to identify several small parcels on a print map. The key numbering system is working, but since several parcels have the same attributes, it is redundant and confusing to list them all out separately (see below).
[ATTACH=CONFIG]20335[/ATTACH]*
Instead of have numbers 1,2 and 4-7 in the list refer to the same owner, I would much prefer to have just the number 1 in the list and repeated on the map (see below, image created in paint, not in).
[ATTACH=CONFIG]20336[/ATTACH]*
My organization has produced maps before I was around with this form of key numbering; I believe they were using ArcView 3.x.
Using ArcGIS 10.1 Advanced for Desktop.
*Names have been changed to protect privacy.
Thanks for the help,
Ben
by Anonymous User
Not applicable
Scratch that. It was done manually (label with numbered field, text box list). Likely what I'll be doing.
