Is it possible to export to PDF with Attributes using python?
3145
10-19-2012 03:54 AM
OvidioRivero
Hello listers,
I am trying to export a an atlas to a pdf with attributes.  I am trying to do this using python but in the python reference I dont find an option that preserves the attributes.
This is what I find in the the Python help as you can see there is no option for the attributes.
ExportToPDF (map_document, out_pdf, {data_frame}, {df_export_width}, {df_export_height}, {resolution}, {image_quality}, {colorspace}, {compress_vectors}, {image_compression}, {picture_symbol}, {convert_markers}, {embed_fonts}, {layers_attributes}, {georef_info}, {jpeg_compression_quality})
Any help would be appreciated.
Ovidio
JonathanQuinn
Esri Notable Contributor
Isn't the {layers_attributes} parameter what you want to change to LAYERS_AND_ATTRIBUTES?  From the help:
layers_attributes:
A string that controls inclusion of PDF layer and PDF object data (attributes) in the export file.
    LAYERS_ONLY ???Export PDF layers only.
    LAYERS_AND_ATTRIBUTES ???Export PDF layers and feature attributes.
    NONE ???None.
(The default value is LAYERS_ONLY)
JonathanQuinn
layers_attributes:
    NONE ???None.
OvidioRivero
Yes you are correct. Thanks for pointing that out.
