Increase visible range of vector tile basemap
1848
05-10-2023 04:25 AM
NicoGrebner
Hi community,
I am using the Vector Tile Style Editor to adjust the World Topographic Map (with Countours and Hillshade). I want to highlight buildings and need them to be visible on a broader range. However, I can set the visible zoom range only between 16 and 22. There is a Note: "Data for this layer may not be available at all zoom levels". Screenshot attached. Is there a way to make the data available at other zoom levels (e.g. 13)?
(I found changing the "minzoom" of Building entry in JSON would help, but that was not the case.)
Tags (1)
illiakhirilov
Hi have you found a solution?
