How to skip labeling if just a tiny part of a feature is viewable?
2053
5
01-07-2013 04:54 AM
PSArcOnlinePSArcOnline
Is it possible to label a feature only if a specific expansion on the dataframe is viewable (ArcMap 10.1)?
For example, i have made a map series and i want to label some features selected by attribute. On one map site a tiny part of such a feature is viewable. I don't want to label this one because just a very small part of a huge feature is shown on the map.
AnthonyGiles
Honored Contributor
There is a minimum feature size option, but I'm not sure if this will calculate the size on only the visible area:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Specifying_a_minimum_feature_size_for_labe...
Regards
Anthony
AnthonyGiles
Honored Contributor
Regards
Anthony
JonMorris
Yes, the Maplex minimum feature size option only applies to the part of the feature that is in the visible extent.
Thanks, i quickly tested this in the past and i thought it had no effect because this impacts only the real feature size.
I will have a closer look.
Ok, this works. I think i tried something wrong with the units.
Thanks a lot
AnthonyGiles
Honored Contributor
Erik,
Please don't forget to mark the post as answered by clicking the tick on the post that gave you the answer
Regards
Anthony
