How to add ArcGIS map in to Wordpress ?
7027
01-13-2021 12:39 AM
rasindurandika
Hi, I am creating my own site using Wordpress. But I an to add my ArcGIS map (.shp) in to my wordpress site. So ,
1)How can I add this shp file in to wordpress
2)If it can not do, What isa the best solution for it ?
Thank you and Stay safe.
KoryKramer
Esri Community Moderator
Are you trying to embed a map showing the shapefile data?  i.e. a static image, or a webmap?
Or are you trying to include the shapefile data itself as a download?
To include a map, obviously you can just snap a screenshot and include in the blog:)
But if you want to create a web map on ArcGIS Online with the data, you could then embed that map in your blog.  See https://doc.arcgis.com/en/arcgis-online/share-maps/embed-maps-groups.htm
If you want your blog readers to be able to download the original shapefile data, zip the shapefile contents into a single folder.  I found this article about adding media downloads to Wordpress, but if you have specific questions, you should contact Wordpress: https://make.wordpress.org/support/user-manual/content/media/adding-media-to-your-pages-and-posts/ad...
Hope this helps!
Mokwena9
I want to embbed a map that will be queried using wordpress widgets, any ideas on how i can go about
