How do I insert tag colors in Label Expression ?
4725
03-19-2020 09:09 AM
PROBERT68
Honored Contributor
I have a troule writing a tag code to display color in red in the Label Expreesion.  It keeps showing blank
What might go wrong here ?
Here is the code :
"<CLR red='255'>&  [ID] &  "</CLR>" +  "- "  +  [NAME]
What I need is showing numbers in red and street name in black
Example :
300 -  Rancho Road
DanPatterson_Retired
are you going through this page?
Text formatting tags—ArcGIS Pro | Documentation
there are some examples
"<CLR red = '255'>" + "Text" + "</CLR>"
use python or arcade
PROBERT68
Honored Contributor
Will that work in ArcGIS Deskop ?
PROBERT68
Honored Contributor
ahhhh  it worked  had to re-read carefully and found the problem.   Now it is fixed
Take care and Be safe !
