Group layers
4253
14
08-21-2013 01:30 PM
AlexGole1
Is there a script that allows you to cycle through multiple group layers and turn on and off group layers one by one?
Alex
AlexGole1
Seems to me that you should put the export to pdf statement in the GroupLayer true portion of the if else clause.  I would think it is currently exporting every layer out to a pdf since the export to pdf statement is outside the if else clause but within the for loop.
You are right. It worked perfectly. Now I dont know if it is easy to do but I am trying to update figure title name and source ffor each PDF using a table. Any idea how to do so?
Alex
import arcpy, os, sys
myPath = os.path.dirname(sys.argv[0])
myMap = arcpy.mapping.MapDocument(myPath + r"/MyMap2.mxd")
layer = arcpy.mapping.ListLayers(myMap, "Map_Elem_Table_v2")[0]
rows = arcpy.SearchCursor(layer)
# Legend Items
fignumElem = arcpy.mapping.ListLayoutElements(myMap, "TEXT_ELEMENT","FigNumber")[0]
titleElem = arcpy.mapping.ListLayoutElements(myMap, "TEXT_ELEMENT","FigTitle")[0]
sourceElem = arcpy.mapping.ListLayoutElements(myMap, "TEXT_ELEMENT","FigSource")[0]
#create a cursor to access values from attribute table
for row in rows:
    fignumElem.text = str(row.FigNumber)
    titleElem.text = unicode(row.FigTitle)
    sourceElem.text = str(row.FigSource)
# Loop through each Group layer and export to PDF
for lyr in layer:
    if lyr.isGroupLayer:
        print "Turning on Layer " + lyr.name
        lyr.visible = True
        print "exporting map"
        arcpy.mapping.ExportToPDF(myMap, myPath + str(lyr.name) + ".pdf")
    else:
        print "Turning off layer " + lyr.name
        lyr.visible = False
MichaelVolz
Esteemed Contributor
Is Map_Elem_Table_v2 a standalone table or the table associated with the feature class?
If it is a standalone table, I think you need to use the ListTables function to get to the tabular data that you are looking for.
AlexGole1
It is a GDB standalone table. How would I point (link) to this table in my script?
tables = arcpy.ListTables()
# Legend Items
for table in tables:
MichaelVolz
if it is the only standalone table, I think you could access it with index 0.
if there is more than 1 table, then use an if then statement to trap it by table.name and then get to the specific field you are looking for.
AlexGole1
Sorry, I am using a fc. for the legend fig name and source.
