Graphic Table Elements in Data Driven Pages
1961
03-15-2011 12:20 PM
AllisonMuise
Hello!
I have built a mapbook using DDP and my layout includes a graphic table element (Production Mapping) that shows information about the features on each page. The table updates correctly if I flip through the pages in ArcMap, but when I export the pages to pdf individually the table remains static- showing only the information for the first page of the document on every page without updating.
I have tried exporting pages individually and as a book from a stand-alone script, the python window, and File-Export and the results are the same.
Does anyone have any suggestions for making the table update as each page is exported?
Thanks!
Allison
DanHopkins
Thank you for bringing this issue to our attention.
I think you have encountered the following defect:
Bug: 2650
Title: GTE table information is incorrect for each data driven page when exporting to PDF
Bug: 2650 has been fixed, tested, and released into SP1 for Esri Production Mapping 10. Have you downloaded and installed SP1 for Esri Production Mapping 10?
AllisonMuise
Thanks!
After installing SP1 export now works from the file menu!
Unfortunately, the table still doesn't update when I export from a script. As each page exports I need to update a selection and reposition some features. My mapbook is 104 pages long so automation would be a good thing!  Perhaps it's something in my script? Here's my code:
import arcpy
from arcpy import env
from arcpy import mapping
env.overwriteOutput = True
mxd = arcpy.mapping.MapDocument(r"H:\SableIsland\Documents\SIVegAtlas.mxd")
# Identify Layout elements
LE = arcpy.mapping.ListLayoutElements(mxd,"GRAPHIC_ELEMENT","Table1")[0]
WB = arcpy.mapping.ListLayoutElements(mxd,"GRAPHIC_ELEMENT","WhiteBar")[0]
H1 = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","Head_1")[0]
H2 = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","Head_2")[0]
H3 = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","Head_3")[0]
H4 = arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT","Head_4")[0]
ddp = mxd.dataDrivenPages
for pageNum in range(1, 5):
    mxd.dataDrivenPages.currentPageID = pageNum
    df = arcpy.mapping.ListDataFrames(mxd, "Panel")[0]
    # Refresh Pie Chart data
    parcelLayer = arcpy.mapping.ListLayers(mxd, "*Graph", df)[0]
    where = "\"Name2\" = " + str(pageNum)
    arcpy.SelectLayerByAttribute_management(parcelLayer, "NEW_SELECTION", where)
    # Re-position elements to fit new GTE
    WB.elementPositionY = LE.elementPositionY + (LE.elementHeight/2) - .45
    H1.elementPositionY = WB.elementPositionY
    H2.elementPositionY = WB.elementPositionY
    H3.elementPositionY = WB.elementPositionY
    H4.elementPositionY = WB.elementPositionY
    # Export
    r = str(pageNum) + "-" + str(pageNum)
    pdf = r"C:\Users\Allison\Desktop\DigitalAtlas\VegAtlas" + str(pageNum) + ".pdf"
    ddp.exportToPDF(pdf,"RANGE",r)
mxd.save()
del mxd
Any suggestions?
