Export a selected DDP to PDF
3443
06-30-2014 06:48 AM
JohnByrne
Hi all,
I have been trying to find a way to automate the exporting of pdf from DDP. Which i have managed to achieve, through a lot of the posts and scripts on this forum, so thanks for that.
I am now trying to automate the selection of only a couple or one of the attributes so the end user can select one value and print that particular PDF rather than all the records (which is alot!)
I have attached my code,(only learning so please be kind but honest!!) a screen shot of the kind of output I am trying to achieve.
Any advice is welcome.
Thanks in advance
by Anonymous User
Not applicable
Original User: jbarrette
You may want to check out the following sample:
http://www.arcgis.com/home/item.html?id=18c19ec00acb4d568c27bc20a72bfdc8
There are a bunch of sample scripts.  One, in particular, is called "Print DDP pages".  It uses validation scripts to auto populate the GP script tool parameters.
Jeff
