I've recently asked the same question but haven't gotten any replies yet.
The problem I am having is that my "XY Event Source" labels do not work when I convert them to shapefiles.
When I click "Label Features", my points in the shapefiles display a bunch of question marks (?).
I am using the Pigiarniq font which I have downloaded on my computer.
Even when I change the "Text Symbol" from the "Layer Properties" to Pigiarniq font instead of Arial, it comes up as question marks (?).
BTW, this is for ArcMap 10.2
Julien
What does the attribute table show? What is the data type of the attribute used for labelling your features?
One of the fields in the attribute table says: Pigiarniq
etc.
The data type are characters, ex: ᐃᓄᒃᑎᑐᑦ
This looks like the "source" for your "XY Event Source" is not being read properly. Is the source a text file or is it an excel file?
I would try exporting the excel file to a CSV text file and then use that as the source for your "XY Event Source"
When I save it as a CSV file, the font is automatically turned into question marks before I even use it in ArcMap
Have you tried changing the font to something more "standard" like Arial or Courier before saving it as a CSV file?
Hey I've tried this and it still gives me questions marks...apparently its an unreported bug in ArcMap 10.2
your csv file doen"t apply the correct code page to the output...have you been able to add maps with that character set before? and if it appears correctly in both arcmap and excel, they you might want to go that route
