Error converting Labels to Annotation with MAPLEX
2462
11-21-2012 06:34 AM
MaximeDemers
Hello,
I want to convert Maplex Labels to an annotation class which I could then manually edit. I did it through ArcCatalog following :
http://support.esri.com/en/knowledgebase/techarticles/detail/38771
After following all the steps correctly, the output is an empty annotation feature class and a relationship class. The annotation class was made in the same dataset of the linked feature class.
Have any idea what could be wrong?
Thank you,
Maxime Demers
MathewCoyle
Honored Contributor
I find it easier to create annotation from labels through ArcMap. Just right click on your labelled layer and click Convert Labels to Annotation.
MathewCoyle
Honored Contributor
