Editing features does not apply
810
09-23-2025 06:37 PM
Cole-AtmaDev
I've been trying to edit features in this layer. My goal is to remove vertices at the intersecting points between two features in the same layer, but they are not the start nor the end vertex. This has already been determined by the black points layer via a handful of geoprocesssing calculations.
However, when I try to edit the linear features manually by selecting the vertices that I wish to remove and then pressing the Delete key, they show as removed. I then click on Finish and it shows Modify Features Complete. But when I reselect the feature I just updated, the vertices I just removed, remains.
I've already verified everything in this support article : Problem: Unable to Edit Features in ArcGIS Pro
- The linear layer is editable
- The linear layer has a spatial extent.
A video of what I am describing is available here : https://youtu.be/SfK0E2OJdkY
Precision : This layer is in a Feature Dataset, of which a Network Dataset has been built. I imported the layer in another geodatabase which is not in a Dataset, and the editing now works ! However, my question remains, is it because of the Dataset that the editing does not work ?
Thanks in advance for the help,
Cole.
Uploaded by Cole-Atma Dev on 2025-09-24.
Laura
by MVP Regular Contributor
I don't know if it'll make a difference but try saving the edit before you click elsewhere?
