Dynamic text in definition query.
4676
11-22-2013 09:25 AM
Emilbrundage
Greetings,
I would like to incorperate some dynamic text into a defintion query. I am working with data driven pages based off of a cities layer. I would only like to display the boundary of the main city for each page. Inserting dynamic text into the layout is easy enough, but can I also insert the same dynamic text into a definition query? How do I need to change the syntax?
For example, dynamic text used for map text:
<dyn type="page" property="name"/>
Can this be translated into SQL for the definition query?
Thanks!
EDIT: Solved with this page:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00sr00000004000000
RobertBorchert
Honored Contributor
enter the definition query dialog for the features Layer Properties
Click on Query Builder.
Build your definition query here just as you would a search query.  Essentially the definition query is the same as search.
