Dynamic Scale Text Options
9245
09-02-2014 07:56 AM
JustinWest
Hello everyone,
I am working with some dynamic scale text on my map products and have run into an issue. I use two scale text blocks, I use the absolute scale (1:9,000)as well as a relative scale (1 inch = 750 feet). I can get the dynamic absolute to populate into a text box using:
Absolute Scale:
1:<dyn type="dataFrame" name="Main" property="scale"/>
I need to display the relative in a similar way but the only thing I have is the option within the dynamic scale dialog for creating the scale text. Does anyone know how to configure this or if it is possible?
DavidBarnes
Hello Justin,
I got this information from a very helpful colleague; use something like the following, adjust to taste for your needs:
Relative Scale: 1 inch = <dyn type="dataFrame" name="DataFrameName" property="scale" pageUnits="in" mapUnits="ft" pageValue="1" decimalPlaces="0"/> feet
DavidBarnes
Hello Justin,
JustinWest
That was exactly what I was looking for.
RyanKelso
Wow, this is great.  I was trying to do the same thing.  Why on earth are there dynamic text tags that aren't documented in the help!?
DariushAmeli
Very helpful. Thank you David Barnes.
