I am creating a dot density map and want to exclude certain areas (like the airport). If I use a masking layer, will that delete the dots that would fall in that area, or will it simply not place them in that area?
See this link:Is there a way to convert from polygon to points based on population of the polygon similar to dot density symbology If this solution helpful.
You can create polygon feature for all areas that you want to dot density to be.
masking hides... nothing is deleted
Thank you for your response! Do those dots not get represented then? Or are they simply placed elsewhere?
they aren't shuffled elsewhere if that is what you mean. run a test and compare an area before and after masking to see what happens
Signed in members can post, follow updates, and more. New here? Register a free account.
