Difficuilty Opening .mxd file in ArcMap 10.1
4192
08-05-2014 03:26 PM
DanielPeel
I have a .mxd file that I coppied over from a server to my computer, and when I open up the file it freezes when I both double click the shortcut as well as when I manually locate the file and open it in ArcMap. I tried using MXDDoctor to see if there were any issues with the file, and it does the same thing the ArcMap does. I am running version 10.1 on my machine. I was wondering if anyone had any ideas on how to resolve this issue. Thanks.
DanPatterson_Retired
By chance, did the project contain data that may reside on a server and the mxd is having difficulty making a connection to it?
DanielPeel
This could be a possibilit, although I did try opening it from where it is located on the server and still the same issues with both ArcMap and MXDDoctor.
JohnVance
I have the same problem with version 10.2.1.  All file are on the local machine.  A few file may open as I have been having this issue for a week now and save my files every few step. MXDDoctor also locks up..
I have not found anywhere were anyone has overcome this problem
