Creating schematic relationship rule but relationship is not available.
1404
03-03-2014 06:33 AM
JerrodKlug
Background:
I recently created a relationship class between our Manhole feature class (non-network) and our Busbar feature class (geometric network).  It's identical to the relationship class previously created between Switching Facility feature class (non-network) and Busbar feature class.  Previously I created a schematic template with a relationship rule that uses Switching Facility as a container for the Busbar related to it.  Worked Great!  Prior to creating relationship class between Manholes and Busbar, I created a spatial query rule that used Manhole as a container for the busbar within a certain distance to it.  Also Worked!  I decided to create the relationship class between manhole and busbar for more control over what busbar belonged in the manhole container.
Here lies the problem:
When creating a schematic relationship rule, the relationship between manholes and busbar is not available.  I created a new schematic dataset and new schematic template and it still doesn't show that relationship as an option to create the rule.
Please help!
Jerrod
RickAnderson
Trying choosing busbar as the source and see if manhole shows up, if so, just check the reverse relationship checkbox.
JerrodKlug
It turned out the configuration was correct.  I imported a copy of the map document and was able to get the relationship class I expected.  Still researching what is different between the map docs though. Head scratcher at this point... :confused:
Thanks though!
