conert shp into wkt or geojson
10521
7
09-27-2017 03:35 AM
francescarusso
Hi all,
does anyone know how can I convert a shapefile (line) in a wkt or geojson format?
I have Desktop  ArcGIS 10.2.
Many thanks
F
DanPatterson_Retired
lots of 'from' conversions... but little hope with a 'to' conversion using 10.2.  Are you just looking for Arc* conversions or have looked looked outside to other options?
francescarusso
Basically I have to import the shp in a software which apparently is not very flexible regarding projections (Only WGS84). In fact it is not reading some of my shapefiles. So I have been suggested that if  my shp are already in WGS84 geographic coordinates then I have to export to a minimalist format as wkt or geojson and reimporting to GIS and defining the projection as WGS84 (EPSG 4326).
As from my xperience I have never heard about thesefile format, I have done some research and it seems like I can do something with Phyton??I have no clue on how to use it so I tried to use the conversion tool "Json to Features"...not sure I have done the right thing as it seems to make no difference..not sure also on what does this "conversion tool" do to my shapefile. What is it for?
Any suggestion really much appreciated.
Cheers,
NeilAyres
It is very easy to re-project data from one coordinate system to another.
Either use the Project Tool in Data Management / Projections and Transformations,
or (which I use often),
with the data in ArcMap, change the coordinate system of the data frame to the desired projection and then export the data in the coord sys of the df.
Just check the actual coordinate system of the data using Arc Catalog, right click on the data and get the properties / Coord sys page.
What software are you trying to import data into?
NeilAyres
I see that the latest DNR GPS utility has an option to export to geojson.
DNRGPS Application: Minnesota DNR
VinceAngelo
Esri Esteemed Contributor
There are tons of examples of queries using a DA Cursor (arcpy.da.SearchCursor) to select the WKT ('shape@wkt') or Esri JSON ('shape@json')  from a layer source. Take a stab at it, and post your code if you run into trouble.
- V
JoshuaBixby
MVP Esteemed Contributor
Starting with ArcGIS 10.5.x, Features To JSON—Help | ArcGIS Desktop supports a geoJSON argument.
TedKowal
Honored Contributor
