Calculate the centroid of a polygon in ArcMap 10.0
20518
11
04-29-2011 08:12 AM
SophiaGeorgiadou
I am following this guide to Calculate the centroid of a polygon:
http://resources.arcgis.com/content/kbase?fa=articleShow&d=32482
but I get an error saying: "There was a failure during processing. Check the Geoprocessing results..."
Checking the results window i see ERROR 999999: error Executing function
Is the above guide valid for ArcMap 10? If not, how can i achieve what i want?
Thanks in advance
ArthurCrawford
Hi Tom,
You could use the calculate centroids in the Calculate Geometry into a field, export the table to a dbf and use xy events to create a new point featureclass.   The only issue would be not being able to create a centroid inside the polygon.   In a test case, only 3% where outside the polygon for builtup areas (Belize).
Arthur
SBBSBB
Dear all,
I tried to use this script for the calculation of the X and y of the centroid, but I constantly get following error:
ERROR 000539: Error running expression: float("-1357069,51744704 -253911,285439942".split()[0]) <type 'exceptions.ValueError'>: invalid literal for float(): -1357069,51744704
Failed to execute (CalculateField)
Does anyone have an idea what I can do about this?
Thank you very much
Sarah Crabbe
