Problem:
My legend which uses a few image symbols appears distorted when exporting to a pdf. I am using the following steps:
The result of the output legend is:
The symbols actually on the map appear just fine though.
System Details:
Windows 7 x64
ArcGIS Desktop 10.4
Good news. I found an article where this happens in ArcGIS Server here:
40538 - The PrintingTools service produces garbled or pixelated legend patches in PDF output
The solution is:
The solution is:
Has this issue been resolved with printing services created directly in Pro instead of ArcMap using ArcGIS Server services, where you do not need to make the changes in the KB Article 40538?
