Abbreviation Dictionary
5676
7
06-12-2015 08:11 AM
MikeFroese
I am trying to label utilities. I am using Maplex and have created a dictionary. When I go in and engage the dictionary thru properties etc..click apply and refresh etc... it does not change to the abbreviation.
Any ideas!
JakubSisak
Honored Contributor
Not really sure what else could be causing this. I can only suggest going back to the drawing board to test this in a new map this particular features a the only layer in there; Unchecked all strategies except for the abbreviations.  Ensure you click Apply in the layer properties after you make any change in there - clicking OK does not commit any changes.
I can confirm that the data dictionary works well in version 10.0, 10.1 and 10.2 but i have not tested in 10.3
DarrenWiens2
Is there room to place the label without abbreviating? If so, I don't believe it will abbreviate, at least that's what I got from a 2 minute read from the help.
JakubSisak
Honored Contributor
Post your dictionary.  Area you completely replacing words with abbreviations?
MikeFroese
I am completely replacing with Abbreviations. This is a short list just to see if it would work
Thanks
JakubSisak
Honored Contributor
Change all from Keyword to Translation. Then in the Layer Properties -> Placement Properties -> Fitting Strategy Tab -> Check Abbreviate Label -> Choose Option -> Select your dictionary from the list.
Once dictionary is selected;  Again in Fitting Strategy Tab -> Strategy Order (button at the bottom) -> Move Abbreviate label strategy to the TOP OF THE LIST.
Hope this helps
MikeFroese
Still didn't work. Is there something I am not seeing! I tried exactly how you put it a couple different times!
JakubSisak
Honored Contributor
MikeFroese
I went back to the beginning, even looking at the
script in the label expression. I revised it and went thru And reattached
everything and it worked!
Thanks for the help
