10.3 Labeling
9162
10
04-12-2016 07:26 AM
MikeFroese
I have a label expression where I want to not display any building numbers greater than 1000. We went from 10.0 to 10.3. The script worked in 10.0 but not 10.3.
Function FindLabel ( [buildingNumber] )
if ( [buildingNumber] < 1000) then
FindLabel = [buildingNumber]
end if
End Function
Thanks for any help
Mike
AdrianWelsh
MVP Honored Contributor
Mike,
Be sure the check the box for "Advanced" in the expression dialog:
TedKowal
Honored Contributor
What sort of side effects are you getting?  Is Building Number a number or a string that represents a number?  There appears to be nothing wrong with your expression....
I am running 10.4  and had a label script similar to yours and it runs with no problems except that the number is a string number so I had to convert the string to a number......
Function FindLabel ( [MDXID] )
if  Int([MDXID]) < 140 then
 FindLabel = [MDXID]
end if
End Function
MikeFroese
I am using the same parser but get
'Carriage returns are not allowed in simple expressions.'
MikeFroese
AdrianWelsh
Mike, can you make sure you are still using the same Parser to carry out this expression? It looks like this is for the VBScript Parser. It might be a good idea to make sure this is still the case.
MikeFroese
AdrianWelsh
Mike,
MikeFroese
WOW! Do I feel dumb!
I completely overlooked the check box!
Thanks
DarrenWiens2
I'm at 10.2.2, but I get your error if I try to use the expression without Advanced selected.
MikeFroese
Thanks
